Automation/Jenkins controlling NET PwrCtrl HOME
pducai
Beitrag von pducai » Montag 22. September 2014, 13:50
hi all,
i'm trying to work out Jenkins controlling PwrCtrl HOME. Because documentation is not the best I have following problem:
1. explanation of data
when running
curl  http://172.16.82.2/strg.cfg?Auth:user7anel | awk 'BEGIN { FS=",?[ ;]*"; } { print "name: ",$1,"|","hostname: ",$2,"|","IP: ",$3,"|","Mask: ",$4,"|","Gate: ",$5,"|","MAC: ",$6,"|","Port: ",$7,"|","Temp: ",$8,"|","Type: ",$9,"|",$10,"|",$11,"|",$12; }'
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   331    0   331    0     0   6566      0 --:--:-- --:--:-- --:--:--  7355
name:  NET-PWRCTRL_04.0 | hostname:  NET-CONTROL | IP:  172.16.82.2 | Mask:  255.255.255.0 | Gate:  172.16.82.1 | MAC:  00:04:A3:0E:02:4E | Port:  80 | Temp:  H | Type:  Nr. | 1 | Nr. | 2
which as you can see is OK in first row, but second doesn't give a sense (Nr.1, Nr.2.. etc).
I don't see any proper explanation anywhere (how to get info automatically thru REST/http) so it would be good if anyone can point me to any.
Re: Automation/Jenkins controlling NET PwrCtrl HOME
Beitrag von andy » Montag 22. September 2014, 17:26
Home have no temperature. Type=H (Home) Nr. 1 = name of first socket etc.
Regards Andy
pducai
Beitrag von pducai » Mittwoch 24. September 2014, 08:17
thanks, but what i need is documentation for http/REST calls and how to list devices and turn them on/off devices. Is there anything more than just installation documents?
Beitrag von andy » Mittwoch 24. September 2014, 09:22
pducai
Beitrag von pducai » Donnerstag 25. September 2014, 14:55
i've seen this one (german is no problem) but it lacks lot of info how exactly do it and what data exactly means.
for example you don't know how to get
Beispiel:
NET-PwrCtrl:NET-CONTROL :192.168.178.148:255.255.255.0:192.168.178.1:0.4.163.10.9.107:Nr. 1,1:Nr. 2,1:Nr. 3,1:Nr. 4,0:Nr. 5,0:Nr. 6,0:Nr. 7,1:Nr. 8,1:0:80:IO-1,0,0:IO-2,0,0:IO-3,0,0:IO-4,0,0:IO-5,0,0:IO-6,0,0:IO-7,0,0:IO-8,0,0:27.7°C:NET-PWRCTRL_04.0
and I had to dig through source code of web page to find out it's
curl http://x.x.x.x/strg.cfg?Auth:user7anel
but I still don't know how to get other output. Also there is no explanation of 'beispil' data, what is structure of data and how should i read it on commandline. Some real world examples would be great.
Beitrag von andy » Donnerstag 25. September 2014, 16:13
There are two possibilities to control NET-PwrCtrl:
UDP with answer: NET-PwrCtrl:NET-CONTROL :192.168.178.148:255.255.255.0:192.168.178.1:0.4.163.10.9.107:Nr. 1,1:Nr. 2,1:Nr. 3,1:Nr. 4,0:Nr. 5,0:Nr. 6,0:Nr. 7,1:Nr. 8,1:0:80:IO-1,0,0:IO-2,0,0:IO-3,0,0:IO-4,0,0:IO-5,0,0:IO-6,0,0:IO-7,0,0:IO-8,0,0:27.7°C:NET-PWRCTRL_04.0
Please look in the Forum for description. Above "Beispiel:" you will find description of data.
Ajax: this strg.cfg
you find a sample html and description in the Firmware: directory - Ajax Schnittstelle
You need some programmer knowledge.
Regards Andy
