NET-PwrCtrl Batch Control for Windows:
net-pwrctrl.exe
Tool für die Steuerung aller NET-PwrCtrl aus der Windows-Eingabeaufforderung/Bat Datei/eigene Software.
Tool for controlling all NET-PwrCtrl from the windows command prompt/.bat file/own software.
This tool must be released by Windows Firewall.
Test device: net-pwrctrl.exe [IP],[UDP send port],[UDP receive port]
eg: net-pwrctrl.exe 192.168.188.61,75,77
basic_command = net-pwrctrl.exe [IP],[UDP send port],[UDP receive port]
auth = [user],[password]
------------------- Relay -------------------------
Switch relay: basic_command,rel,[relay],[on or off],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,rel,3,on,admin,anel
Switch all relays: basic_command,rel,[relays (byte);0=0ff;1=on],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,rel,01000111,admin,anel
Blinking relay: basic_command,rel-bl,[relay],[(word)on time(ms)],[(word)off time(ms)],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,rel-bl,4,500,0x1F4,admin,anel
Switch off blinking: basic_command,rel,[the same relay],off,auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,rel,4,off,admin,anel
--------------------- IO --------------------------
Switch IO: basic_command,io,[io],[on or off],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,io,3,on,admin,anel
Switch all IO's: basic_command,io,[io (byte);0=0ff;1=on],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,io,0x47,admin,anel
Set IO's direction: basic_command,io-dir,[io (byte);0=output;1=input],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,io-dir,01000111,admin,anel
Blinking IO: basic_command,io-bl,[io],[(word)on time(ms)],[(word)off time(ms)],auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,io-bl,4,0x1F4,500,admin,anel
Switch off blinking: basic_command,io,[the same io],off,auth
- eg: net-pwrctrl.exe 192.168.188.61,75,77,io,4,off,admin,anel
Byte = 8 bit unsigned, word = 16 bit unsigned (also in hex format - 0x).
Answer in 'return.txt' file.
net-pwrctrl.exe help -> for this help
