How to call strg.cfg with Auth (username and password)?
Albert25
Beitrag von Albert25 » Sonntag 16. Januar 2022, 15:46
We have several "NET-PwrCtrl HUT" switches, version "HUT 5.0".
I want to query their status from a script, but cannot get the authentication to work. (the switch uses the default "admin" user and "anel" password)
When I do
curl "http://power-1.example.lan/strg.cfg?Auth:adminanel"
I get
401 Unauthorized: Password required
The same command does work on another switch which doesn't require authentication.
How should the authentication be sent for HTTP queries?
Thanks
Albert25
Re: How to call strg.cfg with Auth (username and password)?
Beitrag von Albert25 » Donnerstag 12. November 2026, 16:10
Well, almost 5 years later, I come across this post. In the meantime, I had found the solution, but forgot to post it here in case others find it useful.
This works:
curl -s --user "admin:anel" "http://power-l.example.lan/strg.cfg"
We use it in this script:
#!/usr/bin/env bash
# Show state of Anel power switches
user=admin
pass=anel
for host in power-l power-p; do
	echo "* $host"
	curl -s --user "$user:$pass" "http://$host.example.lan/strg.cfg" \
	| perl -a -F";" -nle '
	    print "  ($F[7] °C)";
	    foreach $i (0..7) {
	      print "  ", $i+1, " : ", ($F[$i+20]? "ON" : "  "), "  $F[$i+10]"
	echo
done
